Hi Guys, hope this is the right section for this.
I'm having some iussues triyng to set the right value for the retraction on Cura 15.4.6.
With or without retraction i get so much filament and blobs around the print, plus with it ofter some times the pla stop flowing maybe because of Grinding
Can i get any help?
Problem with Retraction
- Cattura3.PNG (12.84 KiB) Viewed 16927 times
- Cattura.PNG (36.03 KiB) Viewed 16927 times
Re: Problem with Retraction
You can check if your restraction distance is too large:
I'm using Cura not repetier for now ><
Where i found those options? And how does them reduce the retraction?
Sorry,i mistook the picture...
This is what i want to show you,you can find it in Cura(i'm using 2.1.3),you can decrease this value to see how it goes:
Made this using repetier with distance at 4mm and speed 40mm/s
will try with cura with higher distance
- 14632497_10209710341308506_1171349803_o.jpg (210.94 KiB) Viewed 16908 times
Again with Cura 15.04.6 speed 30mm/s and distance 6.5 mm. Better but not good enough...could the problem be the temperature 200° too high?
- 14632474_10209710552593788_2044560085_o.jpg (165.14 KiB) Viewed 16902 times
Read this article to make some troubleshooting:
https://www.simplify3d.com/support/prin ... eshooting/
Already tried...don t know what to do xd
What model is your printer?Have you tried the recommended slicer settings we gave in Repetier Host?I think you can have a try.
It's a Prusa i3 pro B, don't remember the recommended settings Xd 40mm/s and 4,5mm?
on top of that i'm quite mad because the driving wheel of the y axis just broke...after little use damn, that's really poor quality. Now i have to wait for some spare parts
