Hi All experts
Finally manage to get G2s X-Y-Z calibrate, but couldn't get neither extruder working, follwing motor wiring exactly as describe. Manual control using Repetier: Extruder#1 doesn't move, Extruder#2 will move Z-axis instead ? Is the firmware need some changes ? Please assist.
Thanks in advance
G2s extruder not working
Re: G2s extruder not working
hi,regarding to extruder not working,please try the following step.
1.the extruder will move until the temperature was raise to 180 degrees for PLA,240 degrees ABS.Please check whether the extruder is heated up;
2.please swap the driver board with x-axis,if x-axis is working,the driver board is good.
3.please connnect the motor wire of the extruder to x-axis .if working,the stepper cable is good.
4.please reburn the firmware.
Thanks Eric,
After reading FAQ, get extruder motor moving filament using in LCD or Repeitor manual mode. Still couldn't get filament to come out running print jobs. Need some Slicer profile examples to setup using PLA 1.75 for test run.
