Heat bed showing 80/0 even when thermistor disconnected
S Burn
Post by S Burn » Tue Oct 04, 2016 8:56 pm
It appears the tape came loose under my heat bed and the thermistor wires shorted....I started getting a max temp error....I uncrossed them and secured them but my LCD panel shows 80/0 all the time and the "H" is on. If i unplug the thermistor from the GT2560 board it still shows 80/0 with the "H".....Is the gt2560 board bad now? I reinstalled the firmware....no change...I unplugged everything except the LCD...no change,
ggg666
Re: Heat bed showing 80/0 even when thermistor disconnected
Post by ggg666 » Wed Oct 05, 2016 4:35 pm
It's weird...
What model is your printer?
Could you attach some pics or videos about the issue(the status of LCD and the board)?
S Burn
Post by S Burn » Thu Oct 06, 2016 10:50 am
Well I changed out the GT2560 board...working again...not sure what was causing it but that fixed it.
Post by William » Thu Oct 06, 2016 11:11 am
You mean you replace it with another new board?
S Burn
Post by S Burn » Thu Oct 06, 2016 11:13 am
Yes I did.....could not figure out why it thought it was 80 all the time.....new gt2560 took care of it...I tried flashing the firmware...did not help
S Burn
Post by S Burn » Thu Oct 06, 2016 11:14 am
Sorry...forgot to mention it is a Prussa I3X pro printer
