Page 2 of 2
Re: GT2560 burnt heatbed socket
Posted: Thu Feb 25, 2016 9:36 am
by Perry_S
Unfortunately this has happened to me as well after about 2 months of use. Same connector for the hotbed.
Can anyone tell me where to find a replacement? Maybe a part number I could cross reference or something. I'd prefer something a bit better quality if possible. Ideally I need both sides since the pcb-side has a little damage as well.
Thanks!
Posted: Thu Feb 25, 2016 3:08 pm
by Sherry
hi,the green socket is not sold on line. can you find it locally? the specifcation is : 2pin 180°,RC508(R),5.08mm.
Posted: Fri Feb 26, 2016 3:52 am
by Perry_S
Yes, I can find these locally but all are only rated to 10 Amps. I can not find any connectors with the 5 mm pin spacing that are rated above 10 amps. I believe the original ones were only rated for 10 amps and used in this 15 amp circuit and the reason we are seeing thesse burning.
Posted: Fri Feb 26, 2016 4:48 pm
by Mark
how about check this one, it says 15A:
http://www.ebay.com/itm/10-Pcs-5-08mm-P ... 1201924630
Posted: Sat Feb 27, 2016 5:49 am
by Perry_S
Thanks,
Was hoping to find something local in the US but I will give them a try.
Posted: Mon May 23, 2016 11:01 am
by judarc
Hi, the same thing to me, but today the damaged was on the main DC power plug, I plan to solder the cables directly to the PCB and see if they don't get hot as soon as I turn the bed on.
