Was setting the z offset and the steppers started making a noise so turned the machine off as I though it was hitting the glass.
Started up again and noticed the software was saying 10 commands waiting and I noticed the Steppers not moving. Gave up at this time.
Next day checked baud rate etc still commands waiting error. II did notice that the stepper motors were turning command g28 but very slow, So slow that you do not notice movement but you can hear the motor and see the lock screw on the motor very slow.
I looked for loose wires but could not find any. While tilting the machine to check the wires underneath I did get a electric shock. Checked again for worn wiring but could not see anything. Power on, and put multimeter on power supply cover which showed .004 so hopefully no more shocks. I checked the voltage on the stepper module and showed 1.2 voltage..
All motors are slow. and when moving the z axis when using the knob on lcd gives a warning buzzer noise.
Any help would be appreciated..
Robert
I3 pro b all stepper motors moving slow
Re: I3 pro b all stepper motors moving slow
Hi, you can check if the motor line of each axis is connected to the corresponding position. Then measure the drive board voltage (0.8-1.2V).
Thanks for the reply William.
Not sure what you mean by
The x and y motors are moving the extruded at a speed of 30 mm per minute. The z motors not sure of speed as it sounds as if a alarm is going off.
What ever the problem is, it affects all the motors and started at the same time.
Tried flashing the board but did not change anything.
Any thoughts?
Robert
I checked the voltage and all set to 1.2 volts. And 5 voltscheck if the motor line of each axis is connected to the corresponding position.
Any thoughts?
Robert
Hi, you can try AUTO HOME to determine if there is a problem with the limit switch; then check if the fan is normal and the z-axis motor is working properly. You can exchange the motor wires of each axis for viewing.
Hi William,
I tried swapping all the motors connections around etc but no luck. I even tried a new driver board with no luck.
I did get a motors to work properly after I pressed the failsafe on the LCD. Each time I move a motor I need to press failsafe. The LCD also sowed hit endstop.
When I start the machine the X, Y maybe Z show a location on the LCD of 0, I have a BL Touch on the machine so the offset is different.
I have tried reflashing bit again no luck.
Any thoughts?
Robert
Any thoughts?
Robert
Oh,156801, you can refer to this:http://www.geeetech.com/forum/viewtopic ... 17&t=17038
Update
Machine all working some problem with firmware and computer not talking to printer so installed laptop as smoepone ? error.
All working now.
thanks for the help.
Robert
All working now.
Robert
