How to change the Dir/Step/Motion of the motor
Admin
Post by Admin » Mon Jan 15, 2018 6:25 pm
The new version of the kit
:D
Update:
You can use the V1.1 or V1.2 to change it:
https://github.com/Geeetech3D/Smartto-T ... plications
NOTE:
Added more options to further
smartto_motor_tool_1_0_forWin.zip
(7.32 MiB) Downloaded 1553 times
Update:
Don't need click "factory default".You need to set correct vaule then restart your printer.
Here I will show you how to change the steps/mm.
MotorController.rar
(7.26 MiB) Downloaded 1466 times
1. First you need choose the right port
2. Click connect
3. Then get status.
then you will get the parameter.
Part 2
Change the direction of the motor
You should ensure X axis stop at here then change the value
A30-stop point.png (720.37 KiB) Viewed 42957 times
2.Refer to this pic and set the correct value
You can change the direction of all axis and extruder motor
As mentioned above, set it to "0" or "1"
VooPoc
Re: How to change the steps/mm
Post by VooPoc » Mon Jan 15, 2018 10:00 pm
I have tried this on my E180 and I get the following error:
Start to initial configuration...
Error, Connecting failed! Details: There were serveral wrong data in profile!
Thanks,
VooPoc
Post by VooPoc » Fri Jan 19, 2018 3:35 am
Thanks, the new version fixed this, however it isn't committing the changes when I click "set".
fr0gman
Re: How to change the Dir/Step/Motion of the motor
Post by fr0gman » Sun Apr 07, 2019 8:40 am
Where is this data for the D200?
Post by William » Sun Apr 07, 2019 1:46 pm
Thanks for your feedback.
Could you give us more details of it?
