Can't get my MP3 shield VS1053 to work
Newbie
Post by Newbie » Sat Aug 30, 2014 8:00 pm
After connecting my Shield to the Arduino, I tried to upload the MP3 shield library demo, but I got the following error messages.
I'm new to Arduino and don't now what to do with these error messages.
Can anyone please help?
Error messages :
Arduino: 1.5.7 (Windows Vista), Board: "Arduino Uno"
Build options changed, rebuilding all
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI (legacy)
Using library SdFat in folder: C:\Program Files (x86)\Arduino\libraries\SdFat (legacy)
Using library SFEMP3Shield in folder: C:\Users\Gebruiker\Documents\Arduino\libraries\SFEMP3Shield (legacy)
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=157 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\libraries\SdFat -IC:\Users\Gebruiker\Documents\Arduino\libraries\SFEMP3Shield C:\Users\GEBRUI~1\AppData\Local\Temp\build5646718471480138372.tmp\MP3Shield_Library_Demo.cpp -o C:\Users\GEBRUI~1\AppData\Local\Temp\build5646718471480138372.tmp\MP3Shield_Library_Demo.cpp.o
In file included from MP3Shield_Library_Demo.ino:28:0:
C:\Users\Gebruiker\Documents\Arduino\libraries\SFEMP3Shield/SFEMP3Shield.h:96:8: error: 'SdFat' does not name a type
extern SdFat sd;
MP3Shield_Library_Demo.ino: In function 'void parse_menu(byte)':
MP3Shield_Library_Demo.ino:164:30: error: 'class SFEMP3Shield' has no member named 'GetVolume'
MP3Shield_Library_Demo.ino:181:15: error: 'class SFEMP3Shield' has no member named 'SetVolume'
MP3Shield_Library_Demo.ino:188:36: error: 'class SFEMP3Shield' has no member named 'GetPlaySpeed'
MP3Shield_Library_Demo.ino:204:15: error: 'class SFEMP3Shield' has no member named 'SetPlaySpeed'
MP3Shield_Library_Demo.ino:230:7: error: 'root' is not a member of 'SFEMP3Shield'
MP3Shield_Library_Demo.ino:278:36: error: 'class SFEMP3Shield' has no member named 'GetEarSpeaker'
MP3Shield_Library_Demo.ino:284:15: error: 'class SFEMP3Shield' has no member named 'SetEarSpeaker'
Star
Re: Can't get my MP3 shield VS1053 to work
Post by Star » Mon Sep 01, 2014 1:58 pm
Dear Newbie,
I am sincerely sorry for the inconvenience we brought to you. It is our negligence that makes you encounter this error because we failed to update the program in time which does not match the file SFEMP3Shield.h.Thanks for your notification, we will update the program at once.
However, you can rest assured that since the MP3 shield can work with the file player Example as you said before; it means the MP3 shield is ok. You can develop your project based on the player Example or try agrain with the new program that we update in our WIKI which is named MP3-TF.zip. Extend our sincere apologies again and thank you very much.
pitchoilcan
Post by pitchoilcan » Sun Sep 07, 2014 10:05 am
Dear friend,
I am sorry to hear that.But I have to tell you that the only thing we can do is to make sure the MP3shield is ok.We can not do the secondary development together with you.In addition, we also do not have the tools for your development.If you are new to arduino,I suggest you to learn something about it.And then,you can do your project by youself.
pitchoilcan
I Can't get my MP3 shield VS1053 to work either
Post by pitchoilcan » Sun Sep 07, 2014 10:13 am
Hello Newbie perhaps you can help me with my vs1053 shield. I can't get mine to work either. And when I ask a question they tell you learn to do it yourself. WFT? Thanks for pointing out that their code is malware.
Newbies Rock!
Caesar Passee
P.s They ask for your cat's maiden name, address tele# this that and the other to register for this forum and are of no help.
bad mojo
Newbie
Post by Newbie » Wed Sep 10, 2014 1:08 am
I updated the config.h file in the MP3shield library and suddenly things started to work for me. Michael P Flaga gave me the link to the correct file. http://mpflaga.github.io/Sparkfun-MP3-P ... ource.html
Pitchoilcan, I don't think a real Newbie can help you out. I'm not used to programming. I only got some freebie codes to work for me. You might give it a try ;)
At least I know my shield works.
pitchoilcan
Post by pitchoilcan » Wed Sep 10, 2014 9:35 am
I got rt-midi mode working thanks to the guys and gall at forum.arduino.cc and www.vsdsp-forum.com
JorgeRobles
Post by JorgeRobles » Tue Dec 30, 2014 5:34 pm
Hi Pitchoilcan,
Would you like to share the way you did or point to the arduino forum thread?
Thanks!
ylh
Post by ylh » Mon Jul 25, 2016 12:32 am
I made a few tweaks and managed to play mp3 on a Leonardo but the sound is just not right. It is slow and had this 'wobbly' quality.
Has any one had any success using a Arduino Leonardo or Mega2560 with the shield?
I can share what I gleaned but the sound is wrong. I don't know where else to look.
