Voice Recognition module stuck when trying to record audio
TechAaron
Post by TechAaron » Sun Aug 11, 2019 5:14 am
I have just received one of the Geeetech Voice Recognition modules and am unable to record commands. Every serial command I try works, except when i send "AA 11" to begin recording, the module returns "Start" over and over again, it never returns "Again" or "No voice" or any other signal, just "Start, Start, Start..." and the only way to stop the device is to unplug the GND or VCC pins and restart it.
Any help would be appreciated.
Thank you
Re: Voice Recognition module stuck when trying to record audio
Post by William » Mon Aug 12, 2019 9:33 am
Hi, Can you provide specific videos or pictures?
So that we can solve the problem better.
TechAaron
Post by TechAaron » Mon Aug 12, 2019 10:36 am
here is a screenshot of AccessPort where tried testing the system. i entered AA 00 and the device responded with "waiting!" and then I entered AA 11 so start recording, and it displayed start over and over again and there was no way to stop it without unplugging the module.
Thank you
2019-08-11 19_34_06-AccessPort - COM4(9600,N,8,1) Closed.png (23.42 KiB) Viewed 9604 times
Post by William » Mon Aug 12, 2019 11:10 am
Hi, you can check the connection between voice recognition module and USB-TTL module is correct.
TXD pin on voice recognition module should be connected to RDX pin on USB-TTL module.
RDX pin should be connected to TXD pin.
If the connection is correct, please check the baud rate of serial software is set correctly.
The baud rate for the voice recognition module defaults to 9600bps.
TechAaron
Post by TechAaron » Mon Aug 12, 2019 1:01 pm
The baudrate is set to 9600, however I am not using a usb to ttl, I am interfacing through an arduino UNO. I have bypassed the processor on the arduino so it is acting as a usb to TTL, and I imagine that if all of the other commands are working correctly, gathering input from the microphone should also work, but correct me if Im wrong.
Thank you.
TechAaron
Post by TechAaron » Tue Aug 13, 2019 7:48 am
I have also tried with a USB to TTL module and I get the same result
Post by William » Tue Aug 13, 2019 9:18 am
You can refer to this:
Write aa 36 in the send area of the serial port software,
and then click Send to switch the serial port receive mode to Common mode.
Finally, the 0xaa11 command is sent to enter the recording of the first group of voices.
TechAaron
Post by TechAaron » Tue Aug 13, 2019 12:13 pm
I set the device to common mode again, and i got the same result:
2019-08-12 21_12_33-AccessPort - COM15(9600,N,8,1) Opened.png (25.63 KiB) Viewed 9534 times
Post by William » Tue Aug 13, 2019 1:33 pm
You can contact your sales to replace it.
cactusharpist
Post by cactusharpist » Sat Jun 06, 2020 3:45 pm
Users browsing this forum: No registered users and 10 guests
