Auto home not working
Posted: Fri Mar 09, 2018 2:28 am
by 20gtpri3pc17
I have a Geeetech prusa i3 pro c.
My problem is that auto home doesnt work. If I click auto home from computer or directly from the printer it stops after moving about 3 mm in each direction(axis), but as i saw on youtube it goes without stopping to the minimum point. If I keep the auto home button pressed or press it multiple times it ignores the endstops and tries to go further.
Thank you
Re: Auto home not working
Posted: Fri Mar 09, 2018 7:20 pm
I think you should check the endstop works or not
You can send Gcode"M119" for a test
Posted: Fri Mar 09, 2018 7:41 pm
by 20gtpri3pc17
the endstop does work if I try to print it stops when the stopper is pressed but it doesn't print in the center where it is located on repetier.
i thought that it has something to do with auto home because it doesnt work either
Posted: Fri Mar 09, 2018 7:58 pm
by 20gtpri3pc17
thanks for the reply
I think the stopper works because if i try to print it (z-axis) does stop as soon as the endstop is pressed, but it doesnt print in the center where it is located in repetier. I thought that it maybe has to do something with auto home because both dont work.
I sent "M119" this is what the log showed:
12:56:04.921 : Reporting endstop status
12:56:04.921 : x_min: TRIGGERED
12:56:04.921 : y_min: TRIGGERED
12:56:04.921 : z_min: TRIGGERED
