Geeetech i3 Pro B or X which should I buy???
I am confused and cannot easily find a comparison. Is the Aluminium bed of the X better than the glass or is the Pro B better? What other information should I use to make my choice? Help please.
Re: Geeetech i3 Pro B or X which should I buy???
You can refer to the following information, PRO B easier to build, and PRO X can print a larger area, you can carefully see PRO X X-axis two sides more stable than the PRO B.
I suggest you buy PRO B because it is more suitable for novice assembly.
