The home setting for the z axis goes the wrong way on my aluminum prusa i3
Ddman114
Post by Ddman114 » Mon Aug 28, 2017 4:28 am
When I auto home the x and y axis go to where there supposed to go but the z axis goes the compleatly wrong direction, when I'd hold the z stopper down ut only stops the motor moving up not down.
I'm not sure if it's a software issue or electrical but I can't find anything helpful online.
Re: The home setting for the z axis goes the wrong way on my aluminum prusa i3
Post by William » Mon Aug 28, 2017 11:06 am
Please check if the Z end stop is OK. And you can use the command M119 to get the status of end-stop.
If the end-stop connection of Z axis is OK, and you have to change the direction of Z axis in configuration.h file.
A post you can refer to: http://www.geeetech.com/forum/viewtopic ... 17&t=17037
Users browsing this forum: No registered users and 5 guests
