'Singing' (and noisy) extruder
Posted: Fri Jan 03, 2020 12:50 am
by Geeeko
One of my extruders (number 3) is extremly noisy. It does make a sound, almost like a tune, varrying depending on the percentage applied to it.
Does someone have an idea about how this could be fixed/improved ?
Re: 'Singing' (and noisy) extruder
Posted: Fri Jan 03, 2020 9:37 am
Hi,Can you hear where the sound comes from?
A cooling fan on the motherboard voice?
If you can reduce the sound, you can try to replace it with a silent driver board.
Posted: Tue Jan 07, 2020 12:22 am
by Geeeko
The noise comes from the extruder driver. The printer has one month and printed very few ;/ That said it seems working, just very noisy.
Posted: Tue Jan 07, 2020 10:09 am
Hi, Is your driver board red A4988?
It does n’t have a mute function.
Posted: Tue Jan 07, 2020 7:50 pm
by Jarda3d
I think that it could be mechanical reason - did you tighten your printer?
Mixing sometime does crazy sounds. Try to use rubber or cork dumper between extruder and frame.
Posted: Wed Jan 08, 2020 4:47 am
by Geeeko
@Jarda3D, I'll give a shot to untigh a bit the screw on the frame althought I don't see why this one would be noisy and not the two others (unless it is unfunctional).
@William,
I'm not sure to understand the question. Do you mean the motherboard ?
In case of here a photo of the driver back:
Posted: Wed Jan 08, 2020 9:05 am
Hi,the A4988 is :
- A4988 测量位置.jpg (192.77 KiB) Viewed 9080 times
