Hello all,
I have still massive problems with stringing:
I reduced / increased retraction, no success. I modified temperature, E-Steps/mm, Filament, ...
Now, the next I will try is to increase the print speed and to use Cura to enable Coasting, which isn't supported by Slic3r.
Any ideas?
Or, can somebody provide an gcode of the Benchy or any other sample which works well on his A20m?
Thanks,
Moritz
Still massive stringing problems with my A20m
Re: Still massive stringing problems with my A20m
Hello Vert,
very interesting, you mean these small balls?
It looks like a kind of back pressure valve to prevent, that the filament is pressed from one filament feed to the other one. But, then it is very clear, why retracting doesn't work so effectively like with single hot ends.
That means, that there is a technical reason, why a color mixing hot end will create more stringing then a single hot end.
Where is the picture from? Is there a discussion about this issue anywhere?
Thanks,
Moritz
Thanks,
Moritz
I increased the print speed, activated wipe and reduced the E-Steps/mm. Now, it is a bit better but still not comparable to what I get with my i3 Pro C.
I will now test Cura which supports Coasting, it may be a good alternative to retractiong, which doesn't work so good with the color mixing hot end.
Moritz
Moritz
I have removed the two balls and still have big stringing problems.
I have tried all distance and speed of retraction.
Have someone found the good settings ?
That is what I call massive stringing !
Here is a picture of a benchy printed with A20m stock with valve probably, dont know(only stepper drivers of X,Y,Z have been replaced by TMC2208 but I am sure that can not modify stringing), I try to join the gcode but I can only attach picture to the post..., I will try by PM.
Settings I remember : (but that shouldn't help a lot, you probably have a mechanical issue)
- layer height : 0.2
- print width : 0.4
- perimeters : 3
- main speed 50mm/s
- outline speed 37.5mm/s
- retractation 5mm at 30mm/s
Some ideas :
- wet filament ? https://www.youtube.com/watch?v=FAXUjZZER5E
- too fast retraction or extruder untight , that could make the filament slip when retracting
- temperature too hot
- cooling fan breaked
NB: stringing is not the only problem you have, some of your surfaces show a lot of rugosity
- print width : 0.4
- perimeters : 3
- main speed 50mm/s
Some ideas :
- 3DBenchyA20M.jpg (121.46 KiB) Viewed 18857 times
may I know what slicer are you using?
and what travel speed you have set.
what was your Max acceleration set in the FW.....
I have the back flow disc removed, but still fighting the stringing.
are you using linear advance, traditional Jerk....
too many variant to play with..
I have set 200mm/s travel speed
8.5mm retraction
30mm/s retraction speed
1.75mm coasting
linear advance disabled.
using S3D V3.11 or Slic3r Prusa results are similar
PLA temp @185C bed 60C
appreciate any feedback
thanks
8.5mm retraction
1.75mm coasting
thanks
I removed the balls, tried all i can do on Cura. Single color prints are really nice, better than my ED3 Pro, but Dual Color look like tihs
Hi,You can refer to:
Retraction speed: 40-50mm/s;
retraction distance: 3-4
This print :
distance : 4
Speed : 40
I think i will try to re-install the balls
distance : 4
Speed : 40
I use simplify 3D with the default A20M profile for PLAmay I know what slicer are you using?
8.5mm retraction
1.75mm coasting
thanks
Linear advance 0.2 but with 0 it is also ok
Travel speed 80mm/s
No coasting
PLA temp 200 or 210
Bed 45
Main speed 50mm/s
Outline 37.5mm/s
3 perimeters
But once again I am pretty sure that is not a settings problem, I never have to fight the stringing on the A20m even with default A20m profile with simplify 3D.
I've updated to Marlin 2.0 but it was printing nice before.
