Prime Tower with Cura 4.0
Posted: Fri Apr 19, 2019 10:54 pm
by abp666
Using Cura 4.0 (with A20M files incorporated). Prime Tower is enabled but it only shows up on the Cura build plate as a shadow. I suspect I'm overlooking something obvious to activate it.
Re: Prime Tower with Cura 4.0
Posted: Sat Apr 20, 2019 6:18 pm
by Gingko
1, Could you please show us a pic for it?
2, Has the model two different colours or only one colour?
Posted: Mon Apr 22, 2019 12:02 pm
by abp666
screenshot attached...model shows two colors. The prime tower is shown in shadow and appears round even though I haven't selected that option.
Appreciate your help...
Posted: Mon Apr 22, 2019 1:51 pm
by Tomyuan
I think you need to click"Slice"
Click"Preview"then you will find the prime tower is in there.
Posted: Mon Apr 22, 2019 11:03 pm
by abp666
I've already sliced it and no prime tower when I tried to print.
When I use preview in layer view the lizard becomes a shadow (along with the prime tower). In X-ray view the lizard is in two (differnt) colors and the prime tower is still in shadow.
Posted: Wed Apr 24, 2019 9:23 am
by Tomyuan
You can try to set the correct Prime tower position(X/Y).
If this part out of the hotbed then it won't show normal. :?
Posted: Thu Apr 25, 2019 8:29 pm
by abp666
Ok...will try...thanks
